DavidHickey
- Jul 23, 2007
- 7
Just have a dumb question as a non mechanic. My 1990 Johnson 100hp has been running rough at idle speeds, I replaced the thermostats which did not help, and ordered carb kits which will be in by the weekend. After I did the thermostats I figured I would check to make sure all the wires were connected good. When I pressed on the back of the 2 spark plug wires on the right hand side while the engine was running I recieved a pretty good shock. Did not get any shock from the wires on the left side. Is this normal or could the wires be bad and need replacing. And if so what symptoms could bad plug wires cause?
David
David
