mike101650
- Feb 18, 2011
- 7
New to me 84 115 hp Yamaha. I bought a service manual but I think it assumes some knowledge that I don't have. It pretty much says to use some special test equip on the spark plugs and wires but doesn't address actually changing or repairing the wires. After cleaning the gas tank and carbs, the thing finally runs and runs great. However, it doesn't run great for ever. Three of the 4 spark plug wires are backing off the spark plugs. I tried to squish the spring that goes over the spark plug tip to make them tighter but had no luck doing that. Since this is 30yrs old and probably has the original wires, I think I will replace them. Now does the wire pull out of the coil?? I pulled on it a little bit but did not want to ruin a coil. So please tell me how it works. What is the secret of getting the wire out of the coil? Also, the only replacement wire I have found is a roll of wire and a bunch of connectors without boots. Can I buy a wire set already made up to just plug in?
