Re: Spark plug size for compression tester?
14mm
And here you thought all along the your sparkplug had inch dimensions. They are 14mm threads and the wrench for it is a 21mm (virtually the same as a 13/16). Other smaller sparkplugs are 12mm and commmonly use a 16mm wrench (virtually the same as a 5/8). Champion, NGK, whatever. We've been putting metric parts in our inch outboard motors for a very very long time.
