Hello,<br />I'm trying to determine what sort of spark plug to use, for best overall performance, on my '64 40HP Big Twin.<br /><br />And more specifically...why, choose one manufacturer over another? (I've searched through the archives for similar comparisons, and it seems like more people lean toward Champion for whatever reason).<br /><br />As a background...when I revived my motor, it did have Champions in it (not even sure if they were the correct spec at the time, and don't recall the #'s).<br /><br />So, when I went looking for suitable new plugs, the store I went to only had NGK's to choose from (and "B6S" was what cross referenced as being applicable).<br /><br />Well, having since installed those plugs, I've also gone through the muriad of cleaning and tweaking, carburators and decarbing...in any case, it runs well and to my satisfaction now...so the question would be, is there any reason (or at least an opinion based on experience) to try out the correct Champion plug instead?<br /><br />The NGK's probably have less than 15 hours total on them, since I only got the boat running and on the water a half dozen times last year since new...so they're definately not in "need" of replacing, just wondering if there is anything to gain w/ Champion...(I generally remove and inspect the plugs after a bit of use, and give them a quick sandblasting shot to clean up the electrodes, so everything's clean and happy to spark).<br /><br />Any suggestions, or perhaps something new to try out (I remember paying a "small ransome" for some fancy G3 or E3 next generation split tip spark plugs for my lawnmower, and it seemed to make a bit of a difference...not sure if there is an option for something newfangled that'd help out...but I can probably afford two to try, per a reccomendation). Thanks
