Spark Plug Question
mccoyrl
Champion no longer makes an "L4J." Someone posted that the replacement for it was a "UL18V." I went to NAPA today and they cross referenced the "L4J" and siad it's replacement was an "811."<br /><br />I have a 1975 Chrysler 55 hp. Just wanting to see if anyone can confirm with the RIGHT plug number.
DP
Re: Spark Plug Question
The UL18V is for the later engines. I don't have a Champion book but my NGK book calls for B6HS.
mccoyrl
There are just too many numbers. THe NGK number they gave me is BUHX. Go figure. :rolleyes:
mccoyrl
Thanks Trent. I checked the site and it gave me a number for NGK plugs. I would still like to know the correct number for Champion plugs however.
alcan
My somewhat dated list shows L4J replaced by L82C champion. See where this will take you. Good luck enjoy!
turtle1173
Ziggy,<br /><br /> I have bought and used both the UL18V and the L82C plugs. The latter was recommended by a marina. The UL18V is a surface gap plug whereas the L82C is the more conventional. Honestly, I can't tell any difference between the two, as far as performance goes. From what I've read, however, the UL18V is supposed be be used with the "magnapower" versions of our engines. I don't believe mine is a "magnapower," however. I may put the L82C back in and see if I can tell any difference since I've got her running better recently. I'm still real new at this but I've learned a lot in a short amount of time. Let me know if I can be of any more help.<br /><br />Shane<br />shanewms@sheltonbbs.com
