spark plug orafice size
medic2051
Anyone know the size of the spark plug orafice on a 1975 johnson 50hp? I may purchase a used compression guage to check the motor, but am not sure of the size I need. <br /><br />Thanks
Joe Reeves
Re: spark plug orafice size
If you're speaking of the threads that the spark plug threads into, that would be 14MM, with the hole itself being approximately 5/8" to 11/16".
sikpnter
How about for a 96 150 fast strike? I'm going to get a comp. tester also but had the same question that medic had thanks.
Paul Moir
Well, I see the '96 150 takes a QL78YC spark plug, which has a 14mm thread just like Medic2051's.
