spark plug gaps
RHW
I would like to know what the champion spark plug gaps need to be for a 1998 Johnson 150 (V6) oceanrunner. I have twins and one engine runs a little rough at dead slow. The plugs are currently gaped between .028 and .035.<br />Thanks <br />****
RHW
Re: spark plug gaps
Hooty, <br />Thank you for the advise on the spark plug gap. One of my engins seems to skip a beat at dead slow troll but runs great at higher rpms. I was thinking it might be a bad plug, plug wire or improper plug gaps. I will regap a set of new plugs and give it a test. The other engine runs smooth as silk trolling. I aslo notice that the plugs were a little oily and wonder if the VRO oil mixing ratio needs adjusting. I just bought this boat, a 1998 Wellcraft 240 Coastal with twin 150's. It had 70 hours on the engine and I have the records. Again thank you for the help.<br /><br />****
Dhadley
Re: spark plug gaps
Make sure you put Champion plugs in.<br /><br />Good luck!
