what is gap for plug spl77jc4 used on 9.9 Johnson 1982
The recommended plugs for that engine are now Champion QL77JC4 or QL82C gapped at 0.030"
When new it would probably have had QL77J4 plugs gapped at 0.040"
QL77JC4 replaces those and sometime in the 1980s the recommended gap was reduced , across the board to 0.030" Nobody now seems to remember the reason for the change in gap.
If you happen to live in a country ( almost every country except the USA ) where NGK plugs are more common BZ7HS-10 are the ones to use ( not resistor plugs such as BR7HS-10)
