Spark Plug Gap 50HP Merc
Jesse75
Serial # 0G270011 1995 or 1996? 50hp fourstroke EFI
Trying to verify what model of NGK spark plugs to use.
NGK has this....
YearEngineModelStandard PlugV-Power PlugG-Power PlugIridium PlugPlatinum Plug
2001-1995 50 HP 50, BIGFOOT n/an/an/an/a
No Year Listed 50 HP FOURSTROKE 50 EFI BIGFOOT, EFI n/an/a n/a
The top one uses standard plug. NGK-DPR6EA-9 and no Iridium GAP is .035
The bottom uses standard plugs NGK-[FONT=Arial, Helvetica, sans-serif]DCPR7E and Iridium DCPR7EIX. GAP is .031[/FONT]
[FONT=Arial, Helvetica, sans-serif]Mercury parts catalog is saying NGK-DPR6EA-9
I'm just confused if I can use or should use the Fourstroke EFI with no year listed Iridium plugs?
[/FONT]
Jesse75
This is off of Iboats. I have a 1996 4-Stroke EFI. but they never have EFI listed on any charts. The 2006 can take a DCPR7E. NGK parts list says it gap is .031 here it says .035?
50504-cyl. 4-Stroke1995 - 2001DPR6EA-9 (1)--0.035
50503-cyl. 2-Stroke2001 - 2006BPZ8H-N-10 (1)--0.040
50504-cyl. 4-Stroke EFI2006DCPR7E--0.035
Fun Times
You have a 1995 model number 1F50412RD.
The safest thing to do would be to stick with NGK DPR6EA-9 / Merc OEM part number 33-827858Q as that is what is coming up under your serial number.... I have personally noticed in the past that the NGK website doesn't always seem to 100% correct at times on the marine side.
Typically you should be able to find the correct gap size on a sticker someplace on the engine.
Jesse75
Thank you. I went ahead and put the standard ones in. Just thought Iridiums are supposed to be better, and didn't know if I could switch.
