Re: SPARK PLUG GAP - 1989 EVINRUDE 120 VRO OUTBOARD
Guys - SeaHorse, James, DHadley, especially - I made an error. I quoted above, NOTE 2 from the Clymer manual as being the note relating to the motor I have. Although I correctly quoted the note it is actually NOTE 1 that applies to my motor. NOTE 1 reads as follows;<br />OMC recommends the use of champion QL77JC4 or L77JC4 plugs gapped to 0.040 inches. for sustained low speed operation.<br />For sustained high-speed use, OMC recommends Champion QL78V or L78v(non adjustable gap).<br /><br />The long and the short of it is that every thing seems to be pointing to using QL77JC4 plugs for my motor (at least for my application - which is some water commuting but mostly slow to medium speed driving primarily, with a lot of trolling speeds as well). I hope this helps some of you and clears up any confusion I may have inadvertently caused.<br />Cheers<br />Mike
