Re: Spark Plug Fouling
Your plugs wouldn't oil foul which is the most common type as you have a 4 stroke. You should be able to troll(or run at idle) for a very long time without any problems. You may have blown a peice of carbon off, bridging the center/side electrode gap causing a misfire but this too could be eleminated if you are running(or can get) permagap type plugs( no side electrode). Pull your plugs and do a read, should be dark tan colored. Black would indicate a too rich of a situation, so an idle mixture or slide needle (if equipted) adjustment would be in order.
