Crownline 186
- Jul 17, 2007
- 23
I have a 1993 Mercruiser 3.0 XL with Digital Electronic Ignition. Pulled the plugs last evening and found the following: Plug 1 was black and sooty with some small deposits around the base of the plug and the adjustable electrode was clean but black. Plug 2 was not as sooty, but insulator around center electrode was black. Plug 3 looked much like you would expect the plugs in a well running engine to look, no deposits and a light tan color on the insulator around the center electrode. Plug 4 was about like Plug 2. These plugs probably have less than 10 hours on them. Most of the hours were after the carburator was rebuilt by the shop, but installed by me. Last weekend the engine was started for the first time for the season, and started pretty easily. Idle speed per the boat tach was around 1000 rpm. I backed out the idle adjustment screw about 3/4th turn and idle rpm dropped to about 800 rpm and I left it there. I think that my adjusting the idle screw has made the mixture too rich, but the boat performed well accelerating well and cruising well up to rated rpm of 4,800.
Can anyone give me a clue as to what the condition of the plugs is telling me? Do I have carburator issues, ignition issues, or possibly both? This engine has a miss in one cylinder on cold start-up, but after a minute or two of running it goes away, and the engine runs well thereafter, even at idle.
Any guidance would be much appreciated.....
