hello all and thank you for looking. i have an old bass boat with an 85 hp Johnson(1976). the motor starts and idles fine. when i go to w.o.t. it only revs to (guessing) 3000 r.p.m.s and barely moves the boat. i check the spark and it only fires on two cylinders. do a compression test and all checks out decent. check spark again two different cylinders fire the other two are dead as in hold them in your hand and turn the key dead (nothing nada zilch). i keep checking and it likes to bounce here and there and not over there (the spark) and then change cylinders. i bought it used.the previous owner was a parts hanger and got irritated enough to buy another boat. with that said i believe the power pack and two of the four coils to be brand new/ as he informed me and gave me the old parts informing me they were still good as it made no changes to its performance. now my question is this could this be the stator, the trigger, etc... i have two other motors, another 76 and a 78- 85 hp johnson. one the guy gave me and one i took off my old boat... running well. so both are believed to run. is there something i can remove from one of these and install on this to maybe solve my problem. what is the best bet to start with as in if it is less time consuming to just swap motors. both of the others would have to be awakened with oil change, water pump etc.. as this one on the boat has been recently serviced to include all of this. any help greatly appreciated as it is suppose to be 85 here tomorrow and lake Anna sounds good
