Sound Deadening
RomanRegal
Hi,<br />I was wondering what kind of material people are using for soudproofing their inboard engine compartments.<br />Thanks Roman
Bob_VT
Re: Sound Deadening
You can search for DYNAMAT but you will find it to be very pricey. If you have the clearance there is all sorts of sound insulation available but most of it is very very flammable.<br /><br />Bob
CoachHolland
Re: Sound Deadening
I use dynamat on the doors of my Durango and it works extremely well. I never considered it for a marine application, but now that Bob mentioned it, that would work *very* well.
Tufan
Re: Sound Deadening
I used this product called hood-liner worked like a magic, available in any auto store. It was designed to attache under the hood of a truck, one mat does the job, just cut it with box knife and install around the engine compartment or cover. <br /><br />It is a closed cell expanded vinyl-nitrile foam in the form of a mat, one side smooth for applying an adhesive. You can use a spray-on or contact cement. Very durable. Effective to over 225 F.
BoatBuoy
Re: Sound Deadening
Aquaplas if you can find it. Used on submarines for sound deadening.
Bob_VT
Re: Sound Deadening
Just a thought but why not hit a junk yard and strip the sound deadening material from the inside hood or hoods of full size cars. It should be soundproof and heat resistant too.<br /><br />The price should be better too.<br /><br />bob
Catchem
Re: Sound Deadening
Bob,your a genious.Gonna do excatly that for my boat.Thanks
Re: Sound Deadening
Don't Laugh Tooo Hard......<br />But I've found All my Sound-Proofing,+ Panel Padding Foam in Construction Dumpsters............... :D <br /><br />That Lovely Closed-Cell Foam used to pack Everything from Machinery, to Furniture........<br />I've Found,+ Reused it in 1/8th", 1/4",+ 1/2"..........<br />The Thicker Stuff is Much Harder to find.......<br />3 layers of 1/8th" stapled inside my engine box,<br />Really Quieted it Down.........
