cwhite6
- May 7, 2006
- 348
I did a search function on here and read all the results. I am kinda confused. I have a 1994 25hp Nissan electric start (NS25C). I know I have to remove the card and change the gasket behind it to the 30hp one (I plan on using the one I have and using a sharp blade to cut the hole to match the throat size). I have seen on here that I also have to change the timing and remove a block in the tiller handle? I have also seen on here that all I have to change is the gasket. So, which is it? Gasket only, gasket and timing or gasket, timing and block in the tiller? Thanks for all the help folks!
