I have a recently purchased 2001 Mercury 115 efi that is turning my two bottom plugs black(3 and 4 cylinder). Boat wouldn't plane out when I first got it, only sputter with more throttle and eventually die. Ran a compression check, cleaned the vst, new plugs, and changed injectors. Ran the boat for a solid hour around 5200 rpm. Low rpm acceleration is rough but smooths out at mid rpm on up. Cranks right up and idles, but I'm guessing the two rich cylinders are causing the low rpm missing. Can you point me in the right direction? If I need to provide more details just let me know, trying to keep first post as short as possible.
