stevefishes
- Feb 10, 2012
- 11
Previously I fished from a kayak with a plastic hull. My fish finder transducer was installed inside the hull. Can I do the same with an aluminum hull?
Nope,... Won't work,....... Welcome Aboard...
Airmar does not recommend it. The transducer's sensitivity will be reduced transmitting through the metal hull, so you will not be able to see as deeply into the water. However installation in an aluminum hull is acceptable if the thickness is 3.8 mm (0.15",3/16") or less. The transducer must be epoxied directly to the aluminum hull. Use Airmar models P72, P79, or M260
Where did you get that from??
As long as there is no air spaces the transducer will shoot thru the hull.
Yes it is better to not have to go thru the hull but it will work. For many years when I rented boats I would place the transducer it the rear of the inside of the hull and with a little water around it the transducer shot thru the hull alright. Silicone caulking will also work instead of water.
