Lou C
- Nov 10, 2002
- 12,714
Bearings for 5.2, 6 & 7k Axles - Trailer Parts Superstore Blog
Replacing Trailer Bearings can be a confusing process but some are a little more confusing than others. The 5.2k, 6k & 7K 1.25″ bearings are a prime example of this. The key reason for this confusion is that all three share an identical inside diameter of 1.25″ but are rated for different weight...
blog.easternmarine.com
2.328" cap diameter, bearing # 67048 5200 axle, 6 lug
2.442" cap diameter, bearing # 15123, 6000 axle, 6 lug
2.72" cap diameter, bearing # 14125, 7000 axle, 8 lug
this is good to know in that if your 5200 is marginal you can upgrade the hub and outer bearing to what a 6000 axle has, if for example you are replacing integral disc brake hub/rotors or upgrading an old trailer from drum to disc brakes.
