Hi,
This is my first post, but I am going to ask for help anyway. I bought a 1978 17 ft VIP fish and ski boat from a close friend of the family that need some quick cash. I paid $2900 for it and got it out on the water today. I realize that this is not the preferred way to purchase a boat, but it was better than giving him a loan or letting him get in serious trouble. Anyway it has a 1992 90 hp Johnson V4 outboard on it. Listed below are some of the issues that I noted.
Disclaimer: I did order the OMC manual for this engine before I posted here. I know it is necessary to repair and perform preventative maintenance.
1. Tilt it intermittent going down. This occurs with either the button on the side of the engine or on the throttle. I suspect loose or shorted wiring.
2. Throttle is very stiff going forward and is difficult to control engine RPM with it. Can this be cleaned and lubed?
3. Engine stalls when putting in gear (forward or reverse) unless you move the throttle lever quickly and then you get too much at once. Also noted when returning the fast idle lever to normal engine will stall if moved to normal too quickly from fast idle. Sometimes when moving the fast idle lever to normal, I can hear what I assume backfiring in the carb? It is almost a whoosh or coughing sound. That concerns me some. I do have 3 charged fire extinguishers aboard.
We still had a good day of fishing and being on the water, but this boat has not had a lot of TLC lately.
Thanks for looking and thanks for this outstanding forum!
Stan.
Stan.
