Good day Everyone.
I'm new to the forum, but been reading for a while.
I just have a question regarding my 3 month old tohatsu 9.8 2 stroke (M98B). Is it normal to have some fuel residue around the carb? Ever since I bought the motor, it would stall after idling for a while. From WOT, it would idle at 850-950rpms(been using a tinytach) then after 2 mins or so, it would slowly drop to a stall. Starts again in one pull but will stall again if I don't add gas. After adding about half throttle boost, it would idle normally, then cut out again after a few minutes. I use fresh fuel and valvoline oil most of the time. When I brought it in to the dealer for the 30hour service, I mentioned it to him and they said they would check the carb. I told him that I always notice the carb wet with fuel. Not much, just around the sides and a few drops at the bottom. He reckons it's normal. After the service, they said they checked the carb and found no fault but they replaced the plugs due to fouling?. The buggers charged me labor for opening the carb too.
Any info is greatly appreciated.
