Re: solenoids
Hey, <br /><br />I have an '87 also, same engine.<br /><br />Are you trying to track down a starter problem?<br /><br />Mine was clicking instead of starting, not always, but sporadically.<br /><br />The "helper" solenoid you found has four terminals, two small ones by the base, and two large ones on top.<br /><br />I shorted out the two large posts with a good-sized screwdriver. If the starter turns over consistently when you short them, you found the problem. If not, it may be the other, starter-mounted solenoid or the starter.<br /><br />The "helper" solenoid (OEM) cost me a little under $20 at a marina.<br /><br />HTH, Dean
