Solenoid Question
Jay2310
I have a 1986 150hp Evinrude on a 21 foot Angler.<br />It has been sitting on a trailer for three years.<br />I've been doing a lot of electrical work on it, new battery,starter,power tilt system,ignition switch,gauges so far.<br />My question is, Is there a way to test the Solenoid to determine if it is working properly?<br />Evertime I turn the ignition on the fuse from the ignition to the Solenoid breaks.<br />There is power to the Solenoid.<br />Any suggestions???
tesmel
Re: Solenoid Question
Yes you can apply a 12v d.c source to the two smaller wire and check for continuity across the two larger terminal posts with a multi-tester.<br />I would disconnect all four wires from the solenoid before testing.<br />Hope this helps.<br />Terry
Hooty
Jay,<br />If you're just going to the "on" position and not "start" there shouldn't be power to the starter solenoid. Only in the "start" position. <br /><br />c/6<br /><br />Hooty
Jay2310
Thanks Terry and Hooty!!!<br /><br />Terry I'll give that a try.<br /><br />Hooty, It never makes it to the "start" position.<br />The second I turn the key to the "on" position I hear a click, and the fuse goes. <br />To tell you the truth I only checked for power when the key was off and a good fuse was inserted.
Hooty
I think you've got something beside the starter solenoid shorted, like a gauge or something. If the battery is hot and connected, there is always 12vdc to the big terminal of the solenoid. When you go to "start" you put voltage to one of the small terminals on the solenoid. If the fuse is blowing before "start", it ain't the solenoid.<br /><br />c/6<br /><br />Hooty
mrc
Problem is not likely the solinoid (as others have pointed out). If this was my problem I would <br />proceed as follows.<br /><br />1) Disconnect any accessories connected to the<br /> ignition switch.<br /> Then try and blow another fuse.<br /><br /> If fuse doesn't blow, you got an accessory wired<br /> incorrectly.<br /><br />2) If fuse still blows (not good)<br /> You really need a schematic for your motor at<br /> this point in order to disconnect the items <br /> on the motor which are powered in the "on" <br /> switch position. (example power packs)<br /><br /> After said items are disconnected, try and <br /> blow another fuse.<br /><br /> If fuse blows, its in the wireing between <br /> the switch and the motor, or the wiring in <br /> the motor.<br /><br /> If fuse does not blow, then connect motor<br /> items back in one by one and try to blow a <br /> fuse after each. When fuse blows you have <br /> found your culpret.<br /><br />Hope this helps,<br />Mike
kart33
I had the same deal and it took me 5 hours to find the light socket on the Tach had shorted inside the gauge. Good luck!
Hooty
Instead of blowing a bunch of fuses looking for the short, hook a 12vdc sealbeam headlight across where fuse goes, When the light quits burning (more like glowing) you've found the short. (Another Schematic tip)<br /><br />c/6<br /><br />Hooty
