morpheus847
- Aug 7, 2006
- 22
well im pretty sure my solenoid is going bad. When it's cold outside all it does is click click. If you cross it over and start it and get everything warm then it will start the rest of the day. My question is will a ford solenoid work or a lawnmower solenoid. I've read other places that it will burn out the saftey switch and it grounds throught the mounting plate. But looking at the one thats on it, it grounds the same way wire coming from ground post to base where it's bolted on. Why would a ford solenoid burn out a saftey switch. The only differences i can see is the marine one has rubber surrounding it. My guess is to try to isolate it from vibration.
