where do you get the socket to remove the rod caps for a v4 looper? thanks
L looper power Seaman Joined Jan 23, 2005 Messages 65 Oct 8, 2005 #1 where do you get the socket to remove the rod caps for a v4 looper? thanks
R R.Johnson Rear Admiral Joined Sep 24, 2003 Messages 4,446 Oct 8, 2005 #2 Re: socket for rod bolts? Snap-On , or Mac 5/16-12 point, most others are not strong enough.
B billaranguren@yahoo.com Seaman Apprentice Joined Jun 20, 2005 Messages 41 Oct 9, 2005 #3 Re: socket for rod bolts? I agree - Snap-On. Went through a couple Sears first.
W Walker Captain Joined Jun 15, 2002 Messages 3,085 Oct 9, 2005 #4 Re: socket for rod bolts? Yep, Snap-on is the king but Husky will work too.
G grotmeister Seaman Apprentice Joined Sep 25, 2005 Messages 38 Oct 9, 2005 #5 Re: socket for rod bolts? had same problem in uk not much room on the rod cap found draper pro socket set that fitted
L looper power Seaman Joined Jan 23, 2005 Messages 65 Oct 9, 2005 #6 Re: socket for rod bolts? thanks for the reply...found one
clanton Rear Admiral Joined Jul 9, 2001 Messages 4,876 Oct 9, 2005 #7 Re: socket for rod bolts? Apex, someone on this board should have number.
