so the first numbers are the hp on the ole evinrude ,,,
SeaMasterZ@aol.com
While taking a break from the water pump job, I took some pics of the fleet and its assorted parts ... the number on the evinrude is 10022 10677 - so its a 1962 ten horse? it says sportwin on there, pretty little motor actually, cept for the rather cooked looking cylinder head<br /><br />anyone know how to post pics of something on here, or dont they allow direct posting?<br /><br />thanks
SeaMasterZ@aol.com
Re: so the first numbers are the hp on the ole evinrude ,,,
100_0437.JPG[img]
SeaMasterZ@aol.com
/http://fishingworks.com/Users/UserFolders/SeaMasterZ/PhotoImages/Thumbnails/100_0437.JPG/[img]
SeaMasterZ@aol.com
[/img]/http://fishingworks.com/Users/UserFolders/SeaMasterZ/PhotoImages/Thumbnails/100_0437.JPG/[/img]
SeaMasterZ@aol.com
bump - can someone tell me what I am doing wrong? why arent the pictures showing up?
SeaMasterZ@aol.com
bump!!!<br />HELP!<br /><br />sheesh ... im not askin to crack the code of Hamurabi!
imported_Paul_H
You need to remove the backslash before and after the web address, ie should be
<br /><br />
Chinewalker
Actually, you need to add the www back in front of the address...
<br /><br />Actually, it looks less burned and more simple paint falling off. Typically, motors that have been hot show in the exhaust cover first. If compression is good (80+ psi in each hole) you should be good to go...<br />- Scott
