This a 1990 120 L-Drive Force.
Not knowing this was an unregulated style power system I removed the battery cables from the running motor. Known fatalities are my stereo and apparently my power guage on the dash. The head unit went up in smoke and the volts now read at 16+ (with the key on and motor not running) at the dash as where it used to 13.5 - 14.
I've tested the rectifier and it appears okay. On the negative pole it read 3.60 and 3.61 to each AC and on the positive it read 3.00 and 3.90, while no reading was apparent while reversing polarity. This is what I'm wanting, correct?
What else is downstream from the stator that could've fried that I should be testing?
Thanks.
Thanks.
