Re: So, after you leave the no wake zone...
If you mean face the bow toward the 'west' (assuming top of diagram again is north) into the wind, and try driving in then, i think it is definately worth a try. I have not tried this, but this could be the key. Usually i always drove in with the bow facing north east, and tried backing in, this is where the bow blows away. I tried to drive in with the bow heading into the slip but by the time i could get it to the nose of the slip again the bow blows away, very frustrating. I'm going to try BACKING into the channel between the slips and drive it in that way and see how it works, otherwise im at a total headspin as to how this can be done without alot of yelling, and hands on help. If we have someone go through the front window and reach the dock with the hook-pipe grabber thing, it has helped.....but if you miss, you have to start ALL over again. definately worth a shot. thanks, i think your onto something.
This situation is where a bow thruster would totally eliminate this problem, or even Twins running one in forward and the other in reverse, but that could be difficult as well. Dont know, never tried, but it has been mentioned by other boaters enabling you to drive it like a bulldozer, it seems like it would work essentially giving you the pushing and pulling power allowing it to spin easily and hold it in position... there just is not a ton of room or time to work with once your in this channel.
