erikjohnnelson
- Jul 15, 2005
- 18
I fixed the tilt trim on my 1989 Bayliner runabout tonight (dirty contact on the solenoid). Took the boat out for a test drive. Was going full throttle when I noticed a slight squeaking sound from the engine. Started to turn toward home when I noticed the power dropping off. Kept it going hoping to make it home when I noticed smoke coming out of the engine compartment. Kept going for short distance as I thought it might have been a belt starting to go. Power was really dropping, so I let off completely. Pulled the engine cover off. Smoke was coming from the large pipe approximately 5 inch diameter (this is the exhaust right???). Smelled like rubber so I assume it was the neoprene couplers got hot enough to start smoking. Meanwhile there was a crackling sound coming from the right side of the engine (I assume the large rectangular shape component on the top of the engine to the right of the valve cover is the exhaust manifold). Anyway, this is where the crackling sound was coming from. The pipe smoldered for a while (5 10 minutes). Eventually, I was towed home. I checked the temp gauge when I got to the dock (I was a little distracted by the smoke and did not check it when I was out on the lake). At this point the engine was still at 250 according to the gauge (this was 20 25 minutes after I shut the engine down). I assumed the engine was seized so I hit the key just to check. It turned over, although the squeak I had heard earlier was still there. After it cooled a little more, I turned it over and gave it some gas. It ran briefly and died. I tried starting it again and gas poured out of the small neoprene tube going from the carb to the valve cover. <br /><br />Does anyone have any idea as to what is going on here? I have a family vacation planned in 8 days where the boat was going to be used all the time. Any constructive input would be appreciated.
