brother chris
- Jul 28, 2002
- 2,063
I have a 30' fairliner with an inboard 350. <br />We hooked up the battery with positive on positive and negative on negative. <br />I then went down to check what the voltage was on the battery. <br />There was smoke coming from the battery.
<br />So we took the wires off the battery. <br />Then I looked for all the wires that connect to the batteries and found 1 red line, and 2 blacks coming from the switch box. There is also a short cable attached against the wall with a connector on each end. I would assume that would be for connecting the 2 positives together on the batteries. <br />So, one of the black wires from the switch box goes to a ground on the engine, the other black wire goes to another ground(on the starter). <br />I only have one battery, so does anyone know which black wire from the switch box goes to the battery? <br />I tried them both and the battery started to smoke. I'm confused about this. It never happened before when we hooked the battery up. <br />Is there a wire that is shorting out somewhere? <br />Any help would be appreciated.<br />Thanks, <br />Brother Chris...
