Guys,<br /> I have a '87 225 that is in great shape. Turns 5800rpm WOT and test 105 to 110 on all 6 cylinders. BUT I have this one nagging problem.<br />On cold startup or after it has sat off an 30 minutes or longer, it smokes like a fogger! Once you run it for a few minutes or so it is fine and will not smoke unless you stop for 30-60 minutes and then restart. <br />I know I will get some smoke on startup as this model predates Quickstart. I am the original owner and it never used to smoke this bad on startup.<br />I have checked the recirculation system and it test fine acording to the manual.<br />I have seen a few post about the VRO "leaking" oil<br />under pressure. The VRO is about 3 years old.<br />Any ideas guys????<br />Reddog
