Smokey
Imallgood
hey guys can't get my 2002 Johnson 70 hp from blowing smoke at idle and just off idle. I have decarbon the motor. Also can't find air leaks in the line. Thanks for helping Tom
jakedaawg
Those are smoky motors to begin with. I would try switching to a better oil. The XD-50 runs pretty clean as well as the Yamaha stuff. If that doesn't help it time to diagnose. Compression test first then start into the fuel system. The factory manual list specific VRO usage tests. You will also need to check fuel vacuum as a fuel restriction as well as air leaks can lead to the VRO over oiling.
