I am getting smoke coming out of my oil fill hole. There is a hose that comes from here and attaches to the top of the flame arrestor. I initially thought I had a bad coil that was causing me to cut off on the water. But now I believe this is the problem. Smoke is coming through this hose and dumping into the flame arrestor and causing the engine to die. What would cause this smoke? It has fresh oil in it. The engine temperature stays between 160 and 170. The oil pressure stays between 20 and about 80. There is no water mixed in with the oil when I pull out the dipstick. Any ideas?
