Re: SMART TAPS
MATTTTT25;<br /><br />The trim will continue to function as before, because the plates do not exert excessive pressure in the horizontal position. Additionaly the plates do not bottom out when compressed since the stroke of the actuator allows the plates to move about 14 degrees above horizontal.<br /><br />Keep in mind that the system is never rigid. <br /><br />Also keep in mind that the tabs will make the boat less dependent on the trim. You will be able to plane easily with the motor trim at 0 - not negative.<br /><br />The name of the game is that we control the amount of lift, and not allow it to escalate.<br /><br />I understand that it is hard to imagine, and the only way is to try them. They just plane work, beyond your expectations.
