Small OD Fuel Hose
ggray
Does anyone know of a source for small OD 1/4" ID marine fuel hose? All I find is hose that is somewhat fatter than the hose that comes with the outboard and tank ( which is $$$, and not long enough anyway).
I have seen smaller automotive fuel hose, but not marine certified.
SumDumGuy
Re: Small OD Fuel Hose
curious why you want to have "marine" fuel hose. If the hose doesn't get eaten by the fuel will the motor care?
ggray
Well, I assumed I had to use marine hose, but maybe I don't.
I thought marine hose was tested to withstand fire for a certain period of time, and automotive was not.
But I'm all ears.
Ophion32
It is a guess that 1/4" od hose is old hose .
The newer stuff is made for all types of fuels .can you change
The fittings
Bob_VT
Marine rated fuel hose is UV resistant, oil resistant and is rated to handle e-10 fuels with alcohol. Oil mixed with gas will destroy old rubber and the add in the e-10 fuel and the hoses do not last long. Boat Fuel Hose Line - iboats
dingbat
Most "automotive" fuel hoses will meet those demands. What separates marine fuel line from automotive hose is the fire resistant cover.
