small hole in boat
war eagle
Hey guys its me again.I am wandern what is the best way to patch a small hole in my boat.I was thinking about using jb weld.Is this ok to use or is their something else better than that i can use.I appreciate it.
war eagle
Re: small hole in boat
Oh yea.the hole in it is only a small screw hole in back of boat near the plug.
LubeDude
I wonder how the hole got there,, Hmmmmmmmmmm<br />Someones not telling. Could it be?????????????
JB
I think this is a Boat Question.<br /><br />Moving it there.
Clams Canino
Or if aluminum, a little screw - with marine tex.<br /><br />-W
gsonnier
Go to www.westmarine.com and enter model # 87004 in the search box. I'm not sure if this is the same stuff I used; it looks the same though. It's a stick of putty that you Knead and patch your loose rivet or hole. It works very well and dries as hard as a rock then you sand to finish.
Bigfun
skrew with silicone (same as marinetex?)
Solittle
Bigfun - Silacone is for caulking windows. Marine Tex is a two part product that when cured is as stong as steel and the best thing you can buy for holes & cracks in most anything - ideal for boats & even cures under water. Keep the silacone for use in the home & away from boats.
walleyehed
If it's an aluminum boat, the best fix is to drive a standard aluminum rivet...If it's fiberglass, refer to excellent advice above... :D
war eagle
guys..this is an aluminum jon boat..and i acccidently drilled into the bottom of the boat the other day..i bought some clay/seament stuff and it dryed fast and it is like steel..it is very strong under the water to..this clay works great.I would mention it to anyone to buy it.
LubeDude
It takes a real man to admit to drilling a hole in his boat. Hee, Hee, I did it in my first boat, so dont feel so bad. :D
Boatist
I was told the hole in my boat was to poor money into.
jollymon
It can't be to pour money into, it is only a SMALL hole. To pour money into it has to be a big hole, a great big hole!!!!!
