i hit a log the other day doing about 3 or 4 knots, i pulled the engine up, did a quick visual inspection, and it seemed fine, so i kept on going. spent the rest of that day at low speed.<br /><br />a couple days later, i went out and intended to go full speed, wich is usually around 31 knots on a flat day or 29 if its a little choppy. i coudlnt get above 19.5. the RPM's seemed to be the same (no tach) and the water was glassy, so im thinking it must be the prop. i did a better inspection, and noticed theres an ding on the flange of the body of the propeller. its not huge.. the out of shape spot seems about the size of a quarter. The ding is on the flange on aft end of the cylinder of the shaft. could that little ding really be causing me a 30% loss in efficinecy?
