So, I was doing some maintenance on the my boat (18ft 1979 Thunderbird TriHull w/ Mercury 115HP inline 6 motor) and I noticed that there are two bolts coming through the boat on the inside of the transom, they look to be some bolts for the engine mount. there is a crack in the fiberglass running in-between these two bolts. its about 10 inches long. Is this something I should be worried about? Should i add an aluminum brace (sandwich bracket) Or look at redoing the transom? I am at work right now, but I'll take a pic when I get home and post that for more clarity.
