I have read the FAQ and the "generic boat wiring diagram" thread and still have a question or two about my situation: I have a small 12' aluminum Klammath fishing boat. My current electrical system consists of a 12V deep cycle battery, an electric start 15hp Nissan O/B with alternator output, a MinnKota PowerDrive trolling motor, and a Humminbird fishfinder. Currently, all of these are wired directly to the battery. They work fine, but I'm relocating the battery to the front, and as long as I'm running wires, I'd like to install a master switch and either a fusible link or some other form of circuit protection, just in case something shorts in a big way.
Unfortunately, I can't find the amperage drawn by either the trolling motor or the starter motor, so I don't know what sort of a load to plan for. Does anyone have any rule-of-thumb values to use for the connection to the gas motor and/or the trolling motor? I'd prefer to use circuit breakers on these connections, and will wire them individually to a distribution block.
In my mind, I see the system taking this sort of form:
Battery > master switch > fusible link > distribution block > three individual circuit breakers for the trolling motor, alternator/starter, and "other accessories".
Any thoughts? Does the above seem reasonable, or is it overkill?
Thanks,
Jeff
Thanks,
Jeff
