Sluggish Take Off
ChrisXXX593
I run a 90 hp Yamaha Inshore motor-a 98', on a 17' Flats boat, partial tunnel hull....<br />when i gun it from a stop, it is very slow to go and take off. After it gts going it is fine. I was told to check the plugs and floats? Any ideas?The motor is still very new...less than 80 hours. im still new to this so any help would be apptreciated.
Liam
Re: Sluggish Take Off
Sounds like it's bogging down - too much gas at full throttle before reaching RPM or not enough air. Why do you want to gun it? If you take off at a normal rate of acceleration does the same happen? A good start is to clean your plugs and make sure the carb floats are not sticking.<br /><br />If you feel your post needs to be reposted simply reply to your own message. This gets it to the top of the list. Multiple posts are annoying and cause confusion.
ChrisXXX593
even at a moderate take off its slow to go untill its going all the way...<br />Sorry aboth the multiple posts-still learning.
JB
Howdy, Chris.<br /><br />Ditto what Liam says.<br /><br />Can you give us more info? What prop are you using and what rpm do you get at Wide Open Throttle (WOT)?<br /><br />Red sky at night. . .<br />JB :)
