1977 70 horse Johnson. Starts fine but does not have power. The way the boat acts in the water, I would of said it's the carbs. If you get into the throttle slowly it gets up to about 10 mph and then starts bogging down. I COMPLETELY disassembled all three cards and cleaned with carb cleaner and compressed air. When I started it on the ear muffs, I could tell it did not fix the problem. This motor has always idled like a new one. In fact, the thing looks brand new inside and out. I bet it don't have over 20 hours on it. It would idle down and die. It will rev up (on the muffs) but acts like the timing could be off (sluggish). I noticed while holding the R's at around 2500 that one of the cylinders would randomly miss. Here's what I plan on doing/checking, 1)new spark plugs 2)checking flywheel key 3)inspecting coils for cracks and loose wires 4)checking power pack with ohm meter. Any other suggestion or comments are more then welcomed.
Thanks for your time!
Bart
Bart
