the rebel
- Jul 19, 2005
- 69
Hi everyone, I registered a few days ago and would like to say hello and that it's great to be on board. I just had a great weekend in the Gulf of Mexico with my bass boat. I'm running a 75 Johnson (J75TLCNB), I was told it is an '82 model. Some problems are bugging me. It spits back through the top carb at idle and is sluggish(boggy) right at the bottom of the powerband. This makes it hard to load, and also trolling kinda sucks unless I speed the idle up with the fast idle bar. I have pulled all the carbs down and they are clean as a whistle, floats are set perfect and the throttle linkage is set correctly. Timing is 19 degrees, just like the manual calls for. Compression is 123-125 on all 3 holes. Spark is fat as it gets( I'd be worried about getting bit by it), Jumps over 1/2 inch. I am contemplating a set of Boysen reeds to help with both of these issues. Anyone here know how well these work in this engine? Also, I have been reading some similar posts on this subject, where can I get the idle jets to enrichen the idle mixture on these carbs? Is there a few good hop ups for this engine to boost low end performance? Top end is fine, as I'm not looking to zing it up past 5800 anyway, just for longevity reasons. Is it safe to bump the compression up on these engines and still run pump gas? By how much? I have been around 2 stroke engines for quite awhile so I'm no green horn to the technical aspects of this design. Thanks for any help you can offer. BWJ.
