jiminmontana
- Dec 22, 2009
- 77
I have a mechanical shifting 1958 Evi with 35 hp. When shifting, there is 1.5 inches of play/slop in the shift cable. I can tell that the shifting lever is rotating a lot before acting on the rotary shifting mechanism inside the motor. Am considering jamming a shim inside the linkage to take out all the slop. Is that a mistake?
As things are now (with all this free-travel), I can adjust to either have a forward gear and neutral -- or a reverse gear and neutral. Therre is just not enough EFFECTIVE travel to allow for shifting the full spectrum. So, having forward gear only, that makes things a little dicey when coming in to dock in these strong Montana winds.
Thanks, guys!
Thanks, guys!
