Slips out of gear?
pvisser
Hello All..<br /><br />I have a 1966 80 HP Super Sea Horse Johnson outboard. The engine runs well. However as of the last two trips out the motor will jump out of gear while exclereating, I quickly pull the throttle back to neutral, and then it will go back into gear usually for the rest of the day. This usually happens within 10 minutes of launching, and usually only happens once..<br />Any suggestions where I should look.<br /><br />Thanks
Mod2
Re: Slips out of gear?
Moving to Johnson/Evinrude Troubles forum.
dutchie
Hi, you should take a look at '40hp johnshon outboard problem, please help' by runningbear888 earlier in this forum. It'll give you the answers. Worked for me!
