Slipping, but not the prop. 25 HP Mercury
I just brought my boat about 3 months ago. It's a 14ft aluminum with a 25 hp Mercury tiller. The rig is a 2001. It had a 4 blade 13 pitch composite prop on it when I bought it. The motor ran very strong in the 7 or 8 times I took it out. Well, I hit the bottom ( not very hard ) and it chipped a couple of the blades. That was at the beginning of my day of fish. I ran the motor taking it easy for the rest of the day. I ran strong for a while but the performance went down hill form there. As the day went on the prop just kind a tore a part. When I felt the performance goes down ( like the prop slipping ) I was careful not to over revved the motor. I bought a new aluminum prop. The next time out I could feel slippage when trying to get on plane. It slips so bad that I couldn't get on plane. I try another prop with of course a new hub but had the same problem. It's no jumping out of gear and runs fine at low speed. I tried holding the fly wheel a turning the prop when in gear. It did not slip. I adjusted the trim and tried it in every setting. There is not and information out there that I can find describing the same problem .
Please write with any suggestions.
Thanks,
Patrick
Thanks,
Patrick
