I have a 1974 Chrysler 55hp outboard that has a slight knock in it especially when it decelerates. The guy I had bought it from overheated the motor, I took it home put a new impeller and water pump body in it, ran new gas lines, and fresh gas mix and it started right up. Now the problem I have is a knock in the motor the knock is bad enough that you can feel it if you put your hand on the power head. I have good compression at 120psi cold and I have removed the cylinder head and the pistons and cylinder head look great. I have no problem pulling the rest of the motor apart, but what should I be looking for. Any opinions are greatly appreciated.
