Skinning catfish
Status
Not open for further replies.
PGFISHER
After skinning hundreds of catfish I have found a few tricks. duckbill or electritians pliers work best to peel the skin off. Get good pliers; the dollar store ones spread at the tip and won't grab the skin. The tip of a filet knife is too far from the handle to apply presure to break the skin and makes it hard to get an accurate cut. I use a utility knife. The kind that uses a single edged razor blade gives a clean cut, and the kind with the long slim blade is handy when it gets dull as you can just snap off the end and keep going. Once the skin is off I switch to the filet knife to fimish the job. I guess there realy is more than one way to skin a cat:D
JB
Re: Skinning catfish
Yup. I don't waste time with pliers. A good, sharp filet knife (Rapala, in my case) gets the job done cleaner and faster.
robert graham
Those wooden fish cleaning boards with the big metal clamp on one end help a lot. We were cleaning a mess of fish the other day and used an electric carving knife, and that really made it go faster. They make a pair of fish cleaning pliers with a broad metal blade on it and it works good also. Lots of ways to skin stuff! Good Luck!
badkins50
Same here ;)
Here is one for you. Lake Erie was so muddy I cought this about 3 miles offshore in 40 fow while perchin back in October. A little over 17 inches and boy he had a lot of fight in him. I didn't have the scales with me. My daughter was mad at me when I let him go (perch or eyes only for me). Good Luck.
mommicked
When we have alot to skin we would get a 2x8 or 10 impale the head to the board w a large nail.cut the skin at the skull and down the top of the back then take the trusty rusty duckbill pliers and peel away.sometimes ill twist the pliers to wrap the skin around them a couple of times and wipe the jaws of pliers if they become slimed up. drive the nail through the board at a slight angle to keep the fish from slipping off it and pound the fishhead on it w a 2x4 so you dont poke yourself w it.
sasto
When I was a young'un I pounded a nail thru their tail into a tree. Skinned it with plyers.....I killed that tree, I don't do it anymore. :cool:
mommicked
or as Sasto said put the nail( a big one like for landscape timbers) in a tree or pole or post and cut,grind,file the head off and sharpen.put a tin can on it to keep someone from bumping into it or rathchet strap the board to the tree,post etc and remove it when done.
avaryj
I use the skinning pliers I bought from Walmart a few years back and my razor sharp knife and it takes me about 2 minutes a fish. I bought this comedy DVD about 5 or 6 years ago and it tought me how to skin catfish which was quite ironic. www.worldwidewillie.com its clean comedy for the older at heart but has a fishing show on it. Its very funny but also educationaal when it comes to filleting and skinnin catfish.
vergil
i think thats the chosen method here in the south, thats how we have done it for years?
Silverskeeter
Agreed 100% .Pulling skin makes for a mess that is simple to avoid !Work smarter not harder : )
mommicked
We usually cut the catfish in steaks and deep fried them after skinnin and cutting out the bloodlines.rarely filleting them.:redface:
Casull
I've tried filleting the skin off cats. MUCH easier to skin them before filleting.
Cadwelder
I've seen the nail thru the head more often than any, a couple of cuts and grap the pliers. I personally have fished my entire life but have never skinned or fillet a fish before. I just enjoy the catch and turn them loose. Or if a tournament, weigh 'em in and turn 'em loose.
leesumm
Since moving to Arkansas I have fished nothing but cats. I prefer channel but a flathead or mudcat will do. I was catching the good "pan size" cats then went out with my cousin and then started catching 3 to 8 lb class cats . I know fillet all cats then skin with a 4 inch Rapala or a 6 inch American Fisherman. Much easier and quicker. I can fillet, skin , clean , bread and have in the pan in less than 5 minutes to fish
catfishcarl99
i used to skin and then fillet. but now days i have gotton so good at catting i switched to electric. fast. i can do one under 30 seconds. no skinning no gutting and loose very little meat and for the speed i honestly am not worried about the 3 bites i loose. i catch enough and clean enough that im not making a picasso out of them. if its 2 am and theres 15 fish i want them done effeciently and quickly. im not worried about picking them clean.
reason i say this is cause i know after the video there will be complaints that im butchering and wasting meat. so ill answer it before it comes. i dont care lol. this is how i do it. anyway after i do this i soak in salt water in fridge over night then cut out ribcage. slice off the top 1/4 to 1/2" of the top where the fat strip is and then remove the v of red as well as fillet off the thin red on the outside of fillet. also i use the electric on belly meat after it is out. i do the same as i do on the skin to belly meat. removes the tough inner skin and that nasty gray lining off the inside. just lay it gray lining down and run the electric at a 30 deg angle from the middle out on both sides. nothing but the good white meat after im done. if one fried and ate just a bite of the red stuff by its self they would be amazed at how nasty it tastes. thats the slimy gray you see after its cooked. gives it the fishy muddy taste.
catfish and bluegill take this season. all in quart bags with water sealed with no air. then 4 of them to a gallon bag for added protection.
im dreaming of a white flakey christmas, all wrapped in golden brown.:D
JB
Old thread.
12. Please do not post to threads that have been inactive for more than 3 months UN-LESS you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread. This is considered a hijack. Please start a new thread of your own.
Status
