I have a 2006 Boulton aluminum skiff with an extended transom (what Boulton calls a "gill bracket") and would like to pull tubes and maybe skis with it. It has a wakeboard tower but I don't plan to use that for anything right now. I haven't seen someone with a boat similar to mine towing watersports equipment so I don't know what to use...seems to me just about anything would cause the rope to rub against the motors. I note that I can attach a rope to each of the eyelets in the corner of the transom, but this rubbing thing worries me. Should I just attach the rope to the starboard side eyelet and call it good? The rope would only come close to the motor in a tight-ish left turn. I could also drill holes and attach eyelets to the rear of the bracket...the thing is made of thick aluminum and it would be no problem.
If anyone's struggled with the same question, I'd be interested to know what you did. Thanks in advance.
