jcminnesota
- Jun 20, 2012
- 25
I have a new Alumacraft Classic 16 ft with a 70 Yamaha. I have a boarding ladder on the starboard side. I also have a ski tow bridle with a float attachment that clips onto the port and starboard tow/strapdown brackets. However, the tow bridle is attached on the inside of the top boarding ladder support....and a strong cut by a skier to the starboard side will cause the tow bridle line to be in contact with the boarding ladder top support and pulling against it. The boarding ladder has 4 attachment points with good size bolt/screws into the 2 inch transom...but no backing plates. Will the force be dissipated by the main attachments to the tow brackets? Or will enough lateral force be applied to the boarding ladder support to pull it out of the transom? If your opinion is that I run the risk of pulling out the boarding ladder support then I would ask what the workaround might be. I don't think there is a ski pylon setup for this kind of boat........but maybe someone knows of a supplier. Thanks for listening!
