Re: Ski pylon height?
If you are skiing it looks to be perfect, if you do a lot of wakeboarding it is on the low side for sure. Five feet above the rails sounds way too high to me. For skiing, look at a true ski boat or one used in ski comps the top of the pylon is about 6-12" above the engine cover of an inboard. The reason wakeboarders use such high towers or pylons is to get the lift off the wake. When skiing lift off the wake is the last thing you want, a good waist to shoulder constant pull is what you are after. Just my .02 (30 yrs slalom)
