Skeg repair advice needed
Moody Blue
Well, last weekend my son, really, took the boat out and decided to explore the shore side of the marker buoys. Well needless top say he struck a rock at about 30mph. Fortunately the only damage was a bent/deformed skeg and a slight scar on one blade of the prop.
What I'm wondering is, is it possible to hammer out the damage to the skeg? Anyone done this before that can offer some suggestions?
gss036
Re: Skeg repair advice needed
Depends on how bad it is bent. I have done it, but it takes a lot of patience using 2 hammers. One large and a smaller one, tapping gently up and down the skeg. If it is really bad, may be time to head to a welding shop that does aluminum or use a skeg guard.
Do a google search and you will come up several types.
Chunder06
As gss036 said depends on how bent it is, I cleaned up a big mother of a rock and removed most of the leading edge of the skeg it had a slight bend, I used o piece of wood as a drift and belted it back into shape I then used a wood rasp to reshape the bottom of the skeg then to a file and finally wet and dry paper, with a good coat of paint you can't tell it was crunched.
Bob_VT
If you leave it (no skeg guard) and just get it back into shape you might decide to paint it. Be certain to use zinc chromate primer on the aluminum or your paint job will not last.
If it should happen to break.... a skeg guard or welding will repair it fine. Be sure to have the prop repaired or it will be running out of balance.
Texasmark
And give the paint plenty of time to dry.....helps it to stay put.
Peening is the best way (as mentioned). If you try to grasp it with a large wrench and bend it back, being a casting, it will probably fracture at the bend.
Mark
Moody Blue
Thanks for the advice. I'm going to have a go at it tomorrow. Wish me luck.
THe damage is about 2-3" long on the leading edge of the skeg and is completely folded back (U shaped) by about 3/4". If I'm not sucessful, can I just shape it as best I can and leave it? I will take care of the prop for sure.
